black85vette
- Jan 18, 2009
- 1,084
- 24
I have been tweaking the mill to get things set up the way I like them. So far the spindle lock modification has exceeded by expectations and works a treat (do I have that phrase right?? I am trying to broaden my "English") The magnetic mount for the DI is functioning so well I doubt I will put a DRO on the Z axis.
This weekend I took on the tram adjustment. It just seemed dumb to have a single big nut responsible for holding everything in position not to mention trying to tighten the nut without knocking things out of whack. So here is my solution. I made two "L" brackets out of some existing scrap pieces. They are about .20" thick. I drilled a vertical hole and tapped it 5/16 -24 so that it was centered over the bottom frame part. Then I drilled and tapped some holes in the upright to mount the brackets. I put some tension on both sides and then loosened the nut. Using the two socket head bolts I could then move the upright back and forth until I had it where I wanted it. Then tightened the nut and everything stayed put. While I was adjusting I could easily make .001" changes in the DTI.
Yes I know I can't tilt the head but for the life of me I can't imagine wanting to do that.
