Hi All,
I'm restoring a SB 10L Model # 8187-A, 80% of the lathe
is done cleaned and repainted. While working on the apron the taper pin
got stuck(I hit it in the WRONG direction) and I'm in need of the shaft
for the upper rack pinion gear shaft and the gear perhaps also. The gear
has an oversize hole in it BUT the shaft has the taper stuck and I've tried
for weeks to drill it out with no luck only broken bits.
So anyway I'm in need of an Upper rack pinion gear SHAFT for a 10L
apron SB lathe. If any one thinks they may have it I can send you a pic
of the part so you can double check !
Thanks to all...............Buddy
