- Dec 5, 2009
- 510
- 47
Hi Guys I'm working on building a hand held mortising jig for my palm router, for making loose tenon joints in my woodworking projects.
I am also posting this over on a woodworking forum I belong to as well, as a work in progress, the people over there are recieving this with great acceptance, even though it is all metal maching work, they are enjoying the build process.
Because this is homeshop machining, I am posting this on here as well, to share with my machining friends.
Here is some pics of the work in progress.
I have some left over bar and plate material of aluminum,
1
here is the palm router base ready for layout and cutting of the 1/2" thick aluminum stock
Now after its cut it needs to be machined on its cut edges, to bring everything into square.
Now the screws on the router baseplate are short, so I need to mill out the profile of the router subbase, so it leaves the router subbase thickness left, which is around 3/16" in thickness.
Now to machine out the pocket for the router base to fit into.
it was slow going until I remembered I have roughing end,mills I could use to hog out material quicker.
now to mill out another pocket where the router fence attachment tangs are located on the router base.
now its all milled out ready for dry fit.
to be continued
1
to be continued
