Where to buy thin walled brass tubing?
tmuir
I'm looking for some 1 3/4 inch and 1 3/8 inch brass tubing but need thin walled stuff (between 24 and 30g) and I'm having trouble finding someone that sells this.
I need this to build a couple of engines from Tubal Cains books 'Building Simple Steam Engines'
Yes I know I can use sheet and roll it but I'm lazy and would rather use tube.
If anyone knows of a supplier or has some they are happy to sell please let me know.
Thanks
Tony
Thanks
Tony
I don't know what 24 or 30g is, or if you live in the U.S.A. , but here's a link that might help.
http://www.onlinemetals.com/merchant.cfm?id=84&step=2&top_cat=79
-MB
Hi Tony
It's ( similar )available in UK anyway ...
I'm OK 'cos they are 10 mins from me.. don't know shipping rates ( or if they ship to Aus. ) etc..
Download the .pdf catalogue from :
www.livesteammodels.co.uk
24 Gauge Brass is .020" or .5 MM )
30 Gauge Brass is 0.010" or 0.25mm
So I'm after really thin wall tube.
Both sites you gave list the diameter I'm after but with standard wall thickness.
I personally hate the gauge measurement as the thickness varies depending on what material you are talking about, would much rather it just measured in mm or inches as I understand that.
Sink drains and the like are often very thin wall brass and available in larger cross-sections than the usual K&S tubing.
I'm considering building one of Tubal Cain's plans but will probably use thicker copper pipe for the boiler as I'm not keen on thinwall boilers he uses in the book I have.
Edit: I just flipped through my book and it doesn't look like boiler diameter or wall thickness (above a safe amount of course) is at all critical.
I was about to suggest that source if you can re-design to the available diameters.
Bath lavatories are 1-1/4 and Kitchen are 1-1/2 INCHES (nor sure if that ID or OD)
...lew...
