Hi,
I have a friend who is building a "Clyde Puffer" boat. He wants me to build him a small steam engine to power it when its on the pond. I have come to the conclusion that the simplest but best to build will be a twin cylinder double-acting oscillating engine.
Question:
1. Should the flywheel be large or small to give power?
2. What gives the most power/torque...large bore and short stroke or small bore with large stroke?
3. What rpm's should I be aiming for?
4. Should the cylinders both work together ie. both push/pull together or should they be 90degrees apart?
I will also be building the boiler but do not yet know if it will be vertical or horizontal.
Julian.
Question:
Julian.
