zturgut
- Dec 22, 2009
- 22
- 0
I have just started a "Two cylinder flame eater engine with internal valves" which is an adaptation based on the Jan Ridders Flame Eater engine. Though the operating system is exactly the same there are some differences in materials and the crank shaft design. As I have looked up for the information about this engine, I have had the impression that it needs high precision production to obtain the required vacuum effect and low friction. Because I am not sure I can reach such precision work and low tolerances with my conventional equipment and poor experience I have decided to use stainless steel tubes for the cylinders which provide quite smooth inner surface that you don't have to do anything about it. Depending on my previous experiences on steam engines with stainless steel tubes I finished the new CAD drawings and placed the tubes in an aluminium block stabilizing them by set screws. Against the risk of having problems with transfer of heat between the cylinders and the block I may think of some kind of water cooling. Anyway, we'll see
Zeki
Zeki
