- Dec 28, 2008
- 1,731
- 9
On November 1st I started by building Elmer's #2 as my first project. I chose this simple model to get my winter building session off to a start. Since It was two years since the last time I had machined anything, I needed to refresh my memory and get into the swing of things. I found building this model to be an enjoyable experience and got a little carried away! Since a picture is worth a thousand words the link below will explain what happened.
Link: http://groups.yahoo.com/group/Elmer...ode=tn&order=ordinal&start=1&count=20&dir=asc
The picture below is a closeup taken today of the earlier version of the #2 I built in November. I simplified it by eliminating the pulley next to the flywheel, the cross head guides, and the milled details on the cylinders.
I will build this new version named Two-Bot 50 percent larger and change it's character by adding a few simple ideas.
Day 1: Once the spindle center line was properly located on the workpiece and a vise stop set up, I Simply indexed the base to drill all four corner mounting holes. These will be used to mount the engine to a wooden base.
Below is a picture of the finished base with all the machine work complete and ready for final surface finishing.
Picture below shows the dimensions I used. Note the addition of the four corner mounting points.
If you have any comments, suggestions, or questions please feel free to ask.
-MB
-MB
