Twmaster
- Oct 24, 2009
- 917
- 3
In a Thread by Brian Rupnow Marv posted the following...
I will have the following to make my parts with:
30:1 ratio head. 50 hole plate. I need to make a part with 50 divisions....
So, using the above.... I end up with the number .6 (1/50 x 30) So would that be 6/10 of a rotation or 30 holes on my dividing plate to make that happen?
This unit will not have sector arms. A very simple device.
This is making my head hurt.
With a 90:1 RT, you have to turn the RT handle 90 full turns to make the part turn one complete revolution. Now let's suppose you want to make a 21 tooth gear. That requires turning the part 1/21 revolution for each tooth. That means you have to turn the handle
(1/21) * 90 = 90/21 = 4 & 6/21 turns
for each tooth. That's four complete turns of the handle and 6 spaces (note I didn't say holes) on the 21 hole plate.
Put the pin in one of the holes and bring the beveled edge of one of the sector arms around to touch the left side of the pin. Now, counting the hole the pin is in as zero, count off 6 holes and place another pin. Verify that there are indeed six inter-hole spaces between the two pins. Bring the other sector arm around so its beveled face touches the right side of this last-placed pin. Tighten the locking mechanism that retains this angular separation of the two arms.
Now, when you want to index, swing the locked sector arm assembly so as to put the beveled edge of the sector arm pair against the left side of the indexing pin. Pull the pin and turn it 4 full turns, then continue to the hole that lies next to the other sector arm on the 21 hole ring. Voila, you've moved the handle 4 and 6/7 turns and you only had to count to four. Really, once you understand it, I think you'll agree that it's a very ingenious mechanism.
For any other gear, with N teeth, simply compute:
90/N
and express it in a fraction with a denominator that matches the number of holes in one of your hole circles. Then proceed as above to set the sector arms.
