dgjessing
- Feb 16, 2010
- 295
- 9
So I've gone back and forth on whether or not to do a "Work in Progress" thread on this, or to just build it, see if it works, then do a "Finished Project" post if it does. The first might jinx it or something... But what the heck:
;D
It's going to be similar to this - http://peswiki.com/index.php/Image:Stirling_engine_diagram.gif except I'm planning on moving the displacer with a yoke instead of a connecting rod. I thought it would be good to shorten the length of the tube to the power cylinder as much as possible, and the yoke arrangement helps with that.
Not much to show yet, but I made the displacer cylinder this evening. Started with a really nasty old piece of steel water pipe:
The white stuff on the end is teflon pipe tape,by the way. Teflon is an excellent thermal insulator so I'm thinking I'll make the cylinder + tape a press fit into the aluminum cold end.
Steel end cap brazed in & cleaned up, sitting on the not yet finished drawing:
The displacer cylinder has a 3/4" bore, the displacer will be 11/16" dia. The power cylinder will be 1/2" bore, and the stroke 3/4". The displacer will be aluminum, hollow, 1 1/2" long. The displacer rod and yoke will be brass. The finned cold end will be aluminum, 1 1/2" dia overall. The gland carrying the displacer push rod will be cast iron, and screwed into the cold end. I'm thinking the threads in the cold end will continue all the way through, on the theory that the "fins" formed by the threads will help with heat transfer. The power cylinder will be brass, it's piston aluminum
If any fatal flaws jump out at anyone, please let me know!
Waiting for some stock from Speedy Metals to arrive...
;D
