I've just started on this project and so far It's as far advanced as the drawings are done.
The intention is to build a 10rotor (4inch diameter) running on compressed air or pressurised recirculating water driving a flywheel or pulley in turn driving an alternater.
My research tells me that if i run this at between 40-70psi i should achieve up to 12-15,000rpm. Common sense tells me that i therefore need to achive a good pressure vessel (crank case) Im thinking 3mm wall alluminium tube should be ok. But any advice would be gratefully received.
Im sure that there is some equation or specification for working it out so can someone direct me to it please.:noidea::noidea:
