OK Micheal lets try this again. I inteded to post this am but never quite put the post on the board. You know that four letter word? W-O-R-K. Anyway to answer you questions
Lots of discussion here
http://www.homemodelenginemachinist.com/index.php?topic=1494.0
Here are a couple of excerpts(edited a little to make sense here)
The idea of a general purpose bit suitable for most materials has been mentioned.
The recommended geometry for a GP bit is as follows.
End cutting edge angle 30 degrees
Side cutting edge angle Zero degrees
Side relief 10 degrees.
End relief 10 degrees.
Side rake 15 degrees
back rake 5 degrees.
Nose radius 1/16th inch
For definitions of these terms see the charts posted below
well what does this look like?? since bits are generally small a while back I did a wooden demo to illustrate the concept.
Here is a photo of a right hand bit.
and here is the top view
A left hand version of this would likely work well as a fly cutter.
Hope this helps
I went to machinist school about 11 years ago at the beginning of the lathe block of instruction we were taught the basics of the lathe and tool grinding when we got to the lab we were each given a piece of IIRC 1/4 mild steel and told to grind it like a cutter (general purpose). The cutters we actually used were more or less sharp and ready to go but we had to grind our own as needed. no insert stuff in school. I have been able to grind a usable cutter for whatever need since. Not necessarily the prettiest. As time has gone on they have fewer facets and look more like the text books and photos.
Experience has taught that stoning makes a huge difference in the way a HSS lathe bit cuts.
Entire books have been written about cutting tool material and geometry.
Here are a couple of charts that may help
I prefer 0 degree side cutting angle myself but the larger angles ar better for roughing.
The way a tool is ground also depends on the tool holder for instance a lantern tool post had built in back rake a QC does not.
I ground the form tool to do the little candle holder posted in the galley.
Back rake is not needed for brass and zero back rake will work for other materials as well.
Hope this helps.
And do not limit yourself to facing and cutting tools
you can grind /make your own boring bars
The round one is made from drill rod the the other from a lathe tool blank.
And last but not least form tools like this one.
The tool is on the right the miniature candle stick and a dime for size reference.
For QCTP here is one place to look
www.littlemachineshop.com
Or you can go directly to A2Z CNC
they look like this
Hope this all helps
