Stuart No. 4 build
Hey Simon!
Well Done! I like your thinking and approach! and wonderful photo's!
:bow: :bow:
Bravo! Great thinking applied to a piece of detail that many would have just ignored. Nicely done :)
Well done Simon, isn't great when we think things though. Neat setup.
Don
I haven't been on the forum much lately...
But tonight right away I ran into this thread (again) and read through it.
Excellent stuff. Great pictures too.
I really appreciate the detail and approaches taken. Gives a newbie a feeling of optimism.
Most of us know the extra work it takes just to take pictures and record one's progress. Very much appreciated.
As I'd said in a (much) earlier post...Stuart models was one of the first things that got me interested in this hobby as a kid. Your work is quality.
Simon
Good move on the drill guide inside the steam chest. When I built mine, I was naive and did not think to use a guide. The drill walked. I ended up making the end of the valve rod eccentric, which makes for interesting times putting the engine together. If I'd only known then what I know now, 40 years hence.
Best,
RKlopp
Another Sunday, another day in the shop :)
I got the other side of the valve chest gland profile rounded off, but here's what happens when you go a bit too far on the rounding table:
I should be able to take it out by filing.
I milled the valve chest down to about the right thickness; the outer side is non-critical, and I left is slightly thick because otherwise I start running into the radii for the valve guide and the gland thingy.
Now the valve cover gets a cleanup, first with an old end mill of unknown sharpness, to get through the crust, and then with a nice sharp one on a finish pass:
Then I did something that I might regret, which is to clean up the center indentation. Not having any ball-end mills, I used a little carbide burr that came with the Dremel:
It did the job OK, but I'll have to file away some of the machining marks. I'll need some riffler files to get into the concavity. I say I might regret it because it might make the cover look too too machined, and not like a casting. I guess it depends on how I paint it.
While marking out the valve cover for final size, I also marked out the stud holes:
It's another crazy setup! :D I wanted to drill the cover, valve chest and piston all at the same time to ensure that all the stud holes lined up. So I came up with a setup, using the angle plate as a backing, a 1-2-3 block on each side between which the parts could be clamped, and some spacers at the back to align the top edges of the parts:
Some cardboard takes up the slight differences in thickness between the parts. I set this up so that, if need be, I could repeatably remove and replace the valve chest and cover to drill the piston itself. It turns out I didn't need to do that. One problem with this setup was that the holes are pretty deep, so the drill chuck could hit the 1-2-3 blocks. I had to use a full length drill bit (slightly undersize for the tapping size) to go all the way down into the piston. This worked fine, but I did manage to drill through into the exhaust hole. :-\ Oh well, that's not under pressure so it shouldn't be a problem.
The holes in the chest and cover were then opened up to clearance size (#27) with the part held in a screwless vise, held by hand. Then the holes in the piston were drilled to tapping size (#33), the 4BA taper tap started in the mill by hand, then tapping completed using a tap wrench.
Always a bit nerve-wracking on a part into which many hours have gone, but it went fine.
Now for a test fit:
All the studs look straight, which is a good sign. And the valve chest and cover fit nicely over the studs, so my drilling in-place seems to have paid off.
To end the day, some mock assembly pictures to see how everything fits together:
I have yet to drill the steam hole in the valve chest. I see some engines with steam and exhaust on one side (keep all the pipes together?), and some with steam in one side, exhaust the other. I'm not sure which I want yet.
Simon
I'm not criticising your work Simon, far from it, just bringing up a failure point of most Stuart engine designs.
The left hand picture above shows what I mean perfectly. The flywheel hanging in mid air.
That will ensure the all crank related bearings will get unnecessary wear on them. From the very front one (nearest the flywheel) to the back one AND the big end in between.
Just as a suggestion, I would machine up a small support, so that the weight of the flywheel is taken to task with a bearing either side of it.
Lovely work BTW.
John,
that same problem I will have the day I will bring the Bernay(s) to completion. Not yet decided whether I should fit a supplementar bearing to the wood base or make a metal plate to put both the engine and bearing on.
If I took the additional trouble of making a split bearing, eventual adjustments would be easier.
Marcello
Excellent work Simon. Your documentation is first rate.
gbritnell
What's happened here? Loads of posts missing etc?
NickG: see the "HMEM sold" thread, and other threads. Content posted here is now automatically copyrighted by Group Builder, not by the poster.
Simon
