Silver Soldering
I'm buying this kiln.
Looks like a nicer version of the one I have. You can do lots of cool stuff with a little kiln like that.
I though it was for Hot stuff not cool ;)
J
shred said:
It's easy, but slow unless you keep the kiln hot. :-\
Have you tried silver solder with a kiln?
I have a programable controler that I use for wax burn out so I could write a ramp up and down cycle for silver solder, might need some expermentation.
Dan
Dan
Yeah, it took a couple tries to get tuned up, but it worked pretty well. I didn't do a lot of it though. If you ramp up with the parts in there from cold you may want to get one of the long-lasting fluxes designed for that sort of thing. Obviously you have to use solder pre-forms or solder pastes since you aren't going to be sticking a rod of solder in the vent port. or anything ;D
Same kiln works well for glass fusing, tempering tool steel & melting small amounts of Aluminum or bronze.
