Shop built faceplate for Logan 400
almega
Maumee, OH
I wanted a faceplate for my Logan 400 lathe and even though I could buy one, I thought it would be good experience to make one since I am new to the metal machining trade. I didn't have any cast iron so I decided to make it from A36 hot rolled steel. I bought a piece of 3/4" plate, 6" square and a piece of round bar 2-1/2" in diameter.
I started with the 2-1/2" round which would be the part that will thread onto the spindle. I faced it off, I bored it out so I could cut the 1-1/2 - 8 internal thread and fitted it to the lathe spindle. Once fitted, I threaded it onto the spindle, faced off the other end and cleaned up the outside which ended up being approximately 2-3/8" OD. I then cut a 2-3/8 - 14 thread on the outside of the hub for approximately 1/2".
I then lopped the corners off the square plate to make a rough octagon and chucked in the 4 jaw chuck. I cleaned up the face and bored a hole through it. I then expanded the hole to accommodate an internal thread to fit the 2-3/8 - 14 thread on the hub. I tweaked the thread until I got a very close fit and then threaded the hub unto the plate. I mounted the hub-plate assembly on the spindle and turned the plate round and cleaned up the face.
It is now ready to drill and tap to hold parts for machining as needed.Hub inside.jpg Hub outside.JPG Plate backside.JPG Hub-plate assy.JPG Cleaned up assy.JPG
I actually decided to make it a little more complicated so I added machine screws to secure the plate to the hub so that it cannot unscrew itself, even though not really necessary. It gave me practice drilling a bolt circle, clearance holes, countersinking and tapping blind holes. Screws are 1/4-20.
Beautiful work! Congratulations and thanks for sharing your project with us!
