Cedge
- Jul 12, 2007
- 1,730
- 29
I've always been told that one can't solder aluminum. That has always been one of those unquestioned facts that "everyone knew".
The links in another thread that lead to out of copyright books have consumed more than a few hours of late and one of those old texts describes how to solder the stuff with old fashioned lead/tin solder.
Aluminum oxide is formed as soon as freshly cut aluminum is exposed to air. Aluminum oxide is what forms sapphire and ruby. both are next to diamond on the hardness scale and prevents solder from forming a bond. That all makes sense, so how does one get past the barrier?
The book describes applying the solder with a copper iron and while it is still hot and plenty of flux is still there, brush the intended joint with a wire brush to break up the oxide coating. Apparently the flux gets beneath the coating, erodes it and the molten solder prevents air from reforming the oxides.. The solder then binds with the bare metal and the joint forms a solid bond.
I've not tried it yet, but I think I'm going to have to give it a go, just for the curiosity factor. You could really mess with some minds if it actually works.... not to mention expanding the number of places aluminum can be used effectively.
Anyone here ever had any experience with this "lost" tidbit of information? I also wonder if it would stand up to silver soldering, which came into use many years after the text was written.
Steve
Steve
