- Jun 4, 2008
- 3,285
- 630
As I get closer to the completion of the Halo radial, it seems "natural" that it should drive a propeller eventually. The question of what size to shoot for becomes important as I need to design and make a mount that's high enough to clear the prop when the engine is running.
In watching videos of other radial models, it seems as if a propeller that's twice the diameter of the engine looks "right". The total diameter of the Halo will be around 4". Does an 8" prop seem reasonable?
The end of the steel crankshaft is 3/16" in diameter, so the prop needs to be attached here. I'm iugnorant about how model propellers are attached. Obviously a fast turning propeller is a lot more dangerous than a steam engine model flywheel, so a safe attachment will be critical.
Any advice will be appreciated.
