Philip Duclos Gearless Hit'n Miss IC
Looper7
Philip Duclos Gearless 4 stroke Hit'n Miss Engine
This is where I deviate from the print I have The flywheel on the opposite side so that One can see the magic.
Using the governor balls from Philip Duclos Victorian engine. There are several things I would fix or do better next time. Going to leave things the way they are to remind me about the journey. Calling it finished.
http://youtu.be/ictIvv9WOxQ
9 second preview thanks for watching
http://youtu.be/qcQN4JdSEGg
HD 57 seconds
Jeff Hickenlooper
That is an interesting flywheel. Did you cast brass into the aluminum?
Mike
Mike
These were drilled reamed and then pressed .375 brass bar stock. The flywheel changed as I learned that you need more outer mass to run slower.
Jeff Hickenlooper
