Parting made easy
Discussion in 'Tips and Tricks' started by Paul C, Nov 3, 2019.
  1. Nov 6, 2019 #21
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,299
    510
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    Unfortunately, your reference on HSM refused to offer anything but 'question marks in boxes'
    I'm using a fairly up to date Mac- if that means anything!
    Diverting back to 'Thomas', his stuff is on Hemingwaykits.
    Sadly, the parting off answers could be solved if those wanting information could find where they hid their pocket books and wallets. :p
  2. Nov 9, 2019 #22
    Richard Carlstedt
    Richard Carlstedt
    Richard Carlstedt
    Jul 9, 2007
    47
    16
    Occupation:
    Retired Manufacturing Engineer
    Green Bay ,Wisconsin
    So let me try this to help the thread and first show the concerns a machinist has to start a parting job
    This is shown in the first two pictures.
    The 3rd and 4 th Pictures illustrate what are positives for parting.
    Please note the last photo shows why a rear tool post in mostly succesful because of it's location relative to the cross-slides centerline
    Rich
    kuhncw, trlvn and Paul C like this.
  3. Nov 9, 2019 #23
    Paul C
    Paul C
    Paul C
    Jun 23, 2019
    18
    4
    Gender:
    Male
    Az
    Excellent! Pictures are certainly worth many words
  4. Nov 9, 2019 #24
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,299
    510
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    What lathe is being photographed please?
  5. Nov 9, 2019 #25
    propclock
    propclock
    propclock
    Active Member
    Jan 24, 2012
    43
    10
    Gender:
    Male
    Occupation:
    Happily retired ET
    Crockett calif
    Thanks for that. I must admit I hadn't thought much about the
    parting tool in relation to the cross slide, good on you.
  6. Nov 9, 2019 #26
    stackerjack
    stackerjack
    stackerjack
    Active Member
    Sep 12, 2014
    39
    3
    I parted off a 3" diameter bar of tough steel a while ago. Imagine the tool overhang on that. But I still get jam-ups now and again. Plenty of practice, and a bit of luck are what you need.
    Jack
  7. Nov 9, 2019 #27
    CFLBob
    CFLBob
    CFLBob
    Well-Known Member HMEM Supporter
    Feb 11, 2018
    339
    53
    Occupation:
    Retired Electrical Engineer (Radio designer)
    Central Florida
    The last one I had trouble with was 4" D2 tool steel blank on an 8-1/2 x 20 lathe. The cross slide couldn't be pulled far enough back to put a cutoff tool into the piece after I'd cut in about 1 to 1-1/2". I had to take the tool holder off the QCTP to clean the cut. I broke two cutoff tools. Went looking for a cutoff tool with carbide inserts and can't find one small enough for my tool holders. Most are 26mm, just over 1", my holders are 1/2" - can't handle even 5/8.
    After my luck ran out, I parted it off with a carbide blade on a reciprocating saw. Which generated about a pound of sharp little splinters that I had for a week afterwards.
  8. Nov 9, 2019 #28
    Richard Carlstedt
    Richard Carlstedt
    Richard Carlstedt
    Jul 9, 2007
    47
    16
    Occupation:
    Goldstar
    It's a Boxford Lathe ( Which is the British Version of the Southbend...but Greatly improved !)
    I rebuilt mine (scraped the ways) and it is a bit different. The "Legs" of the carriage were ground parallel to the cross-slide ways, so when (but I never did) I put a Boring table on the carriage, it would have accurate support outboard for the table and be more stable. the ground surface is great for using a mag base indicator too. I am using a Southbend Taper Attachment (cross-slide), but the Tool-slide is Boxford. The ground Starritt Plate you see is for a DRO mounting and makes it really simple AND protected scale mount. you can see the scale just under the small black nob in the closeup picture. Since the top of a Taper attachment cross-slide is parallel already, you put in one pin (to the slide) and indicate the edge with travel and then pin and screw it down. The scale is then placed under the plate and is in perfect alignment and is out of the way (no damage!)
  9. Nov 9, 2019 #29
    Richard Carlstedt
    Richard Carlstedt
    Richard Carlstedt
    Jul 9, 2007
    47
    16
    Occupation:
    Double Post deleted
  10. Nov 9, 2019 #30
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    2,299
    510
    Gender:
    Male
    Occupation:
    Haggis Breeder
    Twixt Tyne and Tees
    Thanks Rich
    You had me baffled as I once had to sort out the damage which 'school children' occasioned before I could use it.
    As you will have read, I'm a Myford sort of creature- and I had mine slideways ground and the worn saddle Turcited. The previous creature who used- misused it ran the gear box on mahogany dust- or so it seemed.
    Thanks for your comments
    Norman
  11. Nov 10, 2019 at 1:36 PM #31
    cobra
    cobra
    cobra
    Jan 24, 2010
    9
    1
    I certainly like the carbide tipped blades.
    I built this holder for 26mm blade that fits my QCTP.
    Makes parting a breeze.
    Jim
    kuhncw likes this.
Share This Page
