Tony Bird
Senior Member
Hi,
Well, from the parts in the biscuit tin we have an engine that runs reasonable well. There are still a few original parts not used, the reversing valve, the ‘T’ pipe connector and the mystery part. It was intended to try and incorporate all these parts in the model and add a few bits of my own.
It had taken me until now to realise what the mystery part was. (P.049).
It was a water feed pump that was actuated by the eccentric on the engines axle. (P.050).
The pump isn’t a very good design as the return spring exerted load on the pumping stroke of the pump, but it was original and would be used. All the parts were interference fits, so just pushed together a bit like the trunnion rods on the cylinders. It was decided to use the pump body and the ram cylinder as well as the spring and the ram assembly, discarding the rest. The body of the pump was drilled though to accommodate a different valve system and the ram cylinder was hard soldered to the body. (P.051).
The usual stand was made to hold the pump to the engines base plate. This finished the work on the pump until a later date. (052).
Before starting on new work on the engine the other steam pipes are fitted to the engines port blocks, these pipes need to be bent and a homemade pipe bender was used. This design of pipe bender works well but will only accommodate one pipe size and produce a fixed radius. But they are quick and easy to make. (P.053).
The pipe bender in use. (P.054).
The steam pipes were test fitted to the engines port blocks. (P.054)
To be continued….
To be continued….
