Hello,
I would appreciate any opinions/comments on an engine design that I have in mind please.
The engine in question is an opposed two cylinder that will run on compressed air. This will not have a lot of run time normally, just run occasionally to show the concept works.
I would like to have a splash lubricating system that will oil the crankshaft bearings, cam, pushrods, and gears.
On the flywheel end there will be a double ball bearing setup and I would like to put two o-rings to seal the crankcase from leakage around the crankshaft.
I know the o-rings would wear quickly down to the shaft size, but if the o-rings only wore slightly larger than the shaft (.001 - .002), would this keep the oil from seeping out on short runs?
Again, this engine would only run for short periods and not subject to any heat to speak of. The bearings are excellent quality and do not have any run out so I do not anticipate any abnormal wear on the o-rings from crankshaft wobble. The crankcase has a large breather directly above the crankshaft/cam and inline with the cylinders. The oil level would be approximately .38 from the bottom of the crankshaft hole. The o-rings that I have have a relaxed ID of .487 and the crankshaft diameter is .500. The rendering is a little dark, but I hope it will show what I tried to explain.
I am not shy about getting opinions so please feel free to be direct if this is a poor idea.
Thank you in advance.
