Allen
- Jul 14, 2008
- 128
- 55
I'm trying to fix a 95 year-old galvanized makeup water tank. It is (was?) riveted, painted, heavy galvanized steel. Unfortunately, the lower sides now resemble Lorraine Swiss. The many, many pinholes are bad enough, but there's also a 9" long horizontal crack about 2" above the bottom on one side, right where the crap in the bottom had accumulated.
Yes, it would probably be easiest to simply replace it but since it is the original tank, I'd prefer to fix it. I'm looking for either 1. a way to make it look original again, or 2. surface patch it to make it look like a vintage repair. There are just too many holes to simply braze/solder it.
Oh, and yes it does need to hold water. It's been suggested that once it's "fixed" I should dump a couple quarts of polyurethane varnish in it and slosh it around. (slosh? it's 2 feet square, almost 4 feet tall, and weighs over 100 pounds! Slowly roll it around the yard, maybe). Anybody have a better idea?
I've got the tank dismounted, I will get photos soon.
