Need help to ID drill chuck taper
TinkerJohn
Active Member
Upper East Side of TEXAS
As usual, I seem to get some oddball stuff and once again I’m stumped! :-\
A few years ago I got an Asian drill chuck with a MT3 taper mount. The darn thing was very accurate and I need to change it to a MT2 taper mount.
The problem is I can’t figure out the taper for the chuck. I’ve tried a JT3, JT33 and JT6 and none of them worked. The best I can measure the chuck taper is .692 on the big end and .643 on the small end with a taper length of 1 inch and that does not match to any taper I know of. Do the Chinese use a taper totally different?
I’ve used several other Chinese chucks and they’ve had the regular JT. Anyone got any ideas what this beast takes? I doubt if you’ll be able to tell much but perhaps the pictures will help someone ID the chuck.
Thanks in advance for the help.
TinkerJohn
www.TinkerJohn.com
John,
This chart might help you on your way, second one down
http://littlemachineshop.com/Reference/Tapers.php
Looking at your dimensions, with almost a 0.050" split over 1" looks like it might be JT6. But as you say you have already tried that - ????????????????
I know it sounds silly, but the taper used is usually marked on the side of the chuck. Maybe that is the Chinese bit, anyone read Mandarin?
Bogs
I thought twice before posting on such an old topic, but this may save someone some time since it took me a few months to find the answer. Persistence pays (maybe?).
The oddball chuck taper is a B18 and is found on drill chucks that come with some Chinese lathes. In fact, the chuck I’m working with came with the Grizzly G4003 (12X36)
BTW: Fairly common does not necessarily mean cheep, in fact the MT2 X B18 arbors I located cost *far more* than the chuck was worth.
---TinkerJohn---
Can you get a stub Morse #2 arbor and turn the weird taper on it yourself?
