chucketn
Senior Citizen
I found a few things at my local flea market today and need help identifying some of them. The first is a large pin type chuck that was on a wooden handle. The handle was shattered so I removed it. Its marked Bridgeport H.M Corp., Made in USA. In the chuck was the chisel like tool in the second picture.
I bought it because I thought it could be used as a tap chuck for the mill or lathe. What is it, really?
Next is a General/MG 0-1 mic and spanner. The spanner is a miniature pin type that fits a threaded sleve in the barrel. The mic needs adjustment as 0 is .025 to the left of the graduation 0 on the barrel. Ive played with it as I might use it for a micrometer stop. The spanner from my Starrett mic fits it,but how do I move zero that far?
Next is what I think is an arm for a dial indicator. It was in the same junk box as the mic and pin vise above.
The shaft has a half ball on the clamp end, and the otherend has been butchered up on a grinder. It is also bent. What did the end opposite the clamp look like originally? I think Ill clean the rough end up inthe lathe after trying to straighten it. If I cant make it straight, Ill make another.
Last is a MT3 drill, 7/8. The drill looks unused unless it was professionally sharpened, but the taper is rough as a corncob. My question here is it worth trying to skim the MT3 to clean it up, turn the MT3 down to MT2, or should I turn it to a strait shank?
Thanks for looking.
Chuck
Thanks for looking.
Chuck
