B
Bogstandard
Guest
Cedge (Steve) told me one time that I should note things down as I have a book inside of me. Little did he know that I had already done that, but on another site.
I have been trying to get my meagre offering onto here for a few months, but due to storage allowances could not be done. Then Rake60 (Rick) approached me and very kindly offered to host the files on his personal space.
I was told that I could make money out of this, but that goes against my morals, as feeble as they are. This is being put on here for the enjoyment of others, at no charge whatsoever.
Now that the preface is written, here goes.
Wanna make one of these!!
Or bling it up and turn it into this ------>
Do you think you are not experienced enough to make one, then read on.
The two engines above were made at the same time in parallel, with the shiny one taking a little bit longer. I designed and built them both as I went along, in just over 2 months. Not all my own work, I did have a bit of specialist input over the design from others on the website (a lot was ignored, but a few were taken on and incorporated into the engines).
I designed it to be made by a total beginner with a medium sized lathe and a vertical slide or small miller. You will find a lot of my hints and tips on here have come directly from this book, and there are a lot more in there.
This book was taken directly from my posts on Paddleducks website, edited by a very kind gentleman only known to me as Floyd (TFL45), to take out most of the 'garbage', and reposted as a downloadable series of 8 PDF files, these if you want to, can be printed out onto 113 pages.
Floyd did a wonderful job, all my 'fag packet' drawings are duplicated at the end in a much larger format, if you see a web page listed, if you click on it, it will take you to that page. A really nice piece of editing.
You will even get to meet my (now) world famous dog 'Bandit'.
Just a bit of info about when I posted it onto paddleducks.
Since I started the post in May 2007
There have been 240+ posts in the article and 7300+ hits, and it is still continuing, so I suspect that a few of these engines are now being built.
There is one major problem, everything is in metric, but the good side is that there is no wierd sizes, everything was designed to the nearest 1/2 millimetre.
So after all that verbal garbage, here are the links to the files.
http://www.rake60.com/photogallery/Piston_Valve_Engine_01.pdf
http://www.rake60.com/photogallery/Piston_Valve_Engine_02.pdf
http://www.rake60.com/photogallery/Piston_Valve_Engine_03.pdf
http://www.rake60.com/photogallery/Piston_Valve_Engine_04.pdf
http://www.rake60.com/photogallery/Piston_Valve_Engine_05.pdf
http://www.rake60.com/photogallery/Piston_Valve_Engine_06.pdf
http://www.rake60.com/photogallery/Piston_Valve_Engine_07.pdf
http://www.rake60.com/photogallery/Piston_Valve_Engine_08.pdf
If you haven't got a PDF reader, you can download for free a version of Acrobat Reader, just put a search into Google.
Just a little more, the text on the post at the beginning does ramble on a bit about safety etc, but it soon gets to the exciting bits of making things.
I made these engines for a few bucks apiece, if you had to make one from retail purchased materials, maybe $80 to $100, but you will end up with an engine that would cost you at least $1000 to buy commercially.
Enjoy
Enjoy
