I've been slowly getting the Powermatic mill cleaned up over the past few weeks. First up was cleaning all the bearing surfaces with WD-40. The mill hadn't been lubed in quite a while and all the moving parts were dry as a bone. I use a mix of Mobil 1 0w20 synthetic motor oil and Lucas oil stabilizer for way lube, about 50-50 mix, also used it on the screws. The Lucas is an emulsifier that helps the oil stick to the surfaces, it doesn't just get scraped off. The old girl responded well to a little TLC, everything moves very smoothly now and requires a lot less force.
On the outside I used Simple Green to remove the dried oil and dirt mixed with chips. It works very well but you need to let it sit for a while to let it do it's job. So it's a repetitive routine: spray some cleaner, let it sit, scrub with a chip brush, let it sit, scrub some more, wipe it up and spray again and start over. Do this till it's clean. It's something to do when I had a few minutes, taking a break or waiting for soldered parts to cool.
Last weekend I mess up some parts for the TB2 and got so disgusted with myself for screwing that up I started installing the DRO on the mill. I hadn't planned on doing this until all the parts for TB2 were done and I had moved the mill to it's final work place but I needed to take my mind off my latest screw-up.
Check out the before and after pics. The after pics shows the DRO scales installed. I've decided to repaint also. This is not going to be a restoration, just clean up and protection. The machine is in good shape and doesn't need rebuilding. But it could stand a little dressing up. There are also a couple screws and bolts that could stand replacing just because I can, but nothing is screaming to be repaired.
Before:
After:
I had been looking at the Uniq DRO from Penn Tools for $720 USD plus shipping, but then checked out Shars. Their DRO was $665 USD including shipping, so that's the one I got. After re-reading Bog's thread about commissioning his new mill, and comparing what I got with his, I think I ended up with the same kit he did.
I still have to install the Z axis scales, but that's going to entail a bit more work and problem solving than I have time for right now.
Before:
After:
