Yep, $25 greenbacks! The contents were worth more than that.
I'm guessing the box is from the mid 60's to late 70's era. The drawers work just as smooth as when they were new. Oh yeah, and I have the keys!
It was loaded up with stuff, had to weigh 30-40 pounds.
Took some time to sort through the stuff and take a quick inventory.
200+ drills, all under .375, most in the numbered sizes.
10 reamers, .375 and under.
20 taps
10 countersinks
3 counter bores
1 counter bore/countersink tool with changeable heads.
several Cleco clamps, no plyers though.
1 snap-ring plyers, inside ring.
Several plug gauges, most very small <.200.
4 small v-blocks, about the size of a US quarter.
several pieces of drill rod.
3 hand scribers.
Lots of punches of various sizes.
A whole vial full of drafting/divider points, about 30.
6 or 7 center drills
2 pieces of 1 inch x 1/2 inch x 8 inch hardened tool steel parallels.
several pieces of HSS tool bits, 3/16, 1/4, 1/2 inch
several depth gauges, some hand made.
hand made angle finder
several bits of aluminum, brass, bronze and steel in usable sizes.
couple pieces of stainless steel brake line, aircraft grade.
Shim stock.
several feeler gauges.
1 2-flute end mill, 3/8.
