Model engine bore size
JamesPruitt
New Member
I am attempting a build of lycoming o360. If you use a 1/4 scale the bore size will be 1.25" is this to big for a model engine
thanks dave
No, model engines can be any size you want. Most of mine are 1" bore. There is no governing body that determines what can and can not be called a "model engine".
I'm with brian on that one. As long as the replica is smaller than the original i would call it a model even if it is only 10% smaller. If the build is the same size then it would be a recreation.
thanks dave
How big is your machinery? I suggest don't try this at home on a Sherline, though there is probably some prodigy who could pull it off with a file and a hammer. On the other hand, you should have no capacity issues, per se, with a Myford or SBL.
thanks for the quick responce will post some pictures as soom as i get started still in design
  • Like
Reactions: gus
