- Oct 29, 2011
- 287
- 2
It seems like every time I use a slitting saw, I mess something up.
Last night I started on the conrod of a Stuart No. 4. It's a gunmetal casting, and gunmetal is tricky to machine; it seems to squirm under the cutter, and move around in ways you don't expect.
So I set up the conrod with a couple of 1-2-3 blocks to hold it square, and went at it:
only to find that I'm about a tenth off on one side:
I think in this case my setup was at fault, but I wonder also if the saw was wandering. I don't really have a feel for the right depth of cut and feed rate for sawing. I'd set the cutting speed to about 150 RPM (100 SFPM x 4 / 2.5" diameter), but anything more than a 0.02" depth of cut seemed to be putting too much force on the part. (It probably doesn't help that I'd previously blunted this blade by running to too fast in steel ;D )
So what kind of depth of cut should I expect from a sharp saw blade in bronze?
[I'm thinking of remaking this conrod from steel, with a bronze bushing anyway. Seems odd to use gunmetal for this part.]
Simon
Simon
