Slitting Saw How To
Discussion in 'Tools' started by Johno1958, May 16, 2018.
  1. May 16, 2018 #1
    Johno1958
    Johno1958
    Johno1958
    Well-Known Member Project of the Month Winner
    Sep 19, 2015
    109
    39
    Hi All
    I have slitting saw job coming up in aluminum . The slitting saw is 63mm which is about 2.5" and 3mm about 1/8" wide and 38 teeth, straight hss blade which gives me the shivers just looking at it. I have looked up Little Machine Shops feeds and speed calculator and treated the saw as a big mill cutter which gave RPM speed of 310 and a chip load of 0.42mm . Feed rate is at nearly 5m or 194 ip per minute which I couldn't crank that fast if I tried..The slots I am aiming for are 5 to 8mm deep no active cooling ,only a squirt of WD 40.What depth of cut should be looking at each pass? My mill is a Sieg X2.7 so it's getting towards the size of an X3.
    Thank you.
  2. May 16, 2018 #2
    bazmak
    bazmak
    bazmak
    BAZMAK
    Dec 12, 2012
    1,969
    1,105
    300 rpm seems ok.Full depth 1 pass should be ok with hand feed
    and trial/error /experience wit plenty of wd 40
    joco-nz and RM-MN like this.
  3. May 16, 2018 #3
    Lakc
    Lakc
    Lakc
    Aug 22, 2009
    985
    42
    Keeping the aluminum from sticking to the teeth is probably the most important part of the process. If you must use wd40, use more than will spray out of a spray can. In other words buy it by the gallon and put it into a large volume squirter type oil can and pump the daylights out of it. Slitting is by far the messiest operation I ever performed but the clean up is better than all the saws the broke in my face ruining the part in the process. I was doing about the same size and depth slots with commercial oil/water mix cutting fluids and using around 3 ounces of fluid in 32mm. Flood is the operative word.
    RM-MN likes this.
  4. May 16, 2018 #4
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    May 23, 2008
    10,293
    3,076
    Johno--I have a few slitting saws, and was taking many passes with about 0.010" depth of cut. Then I read about other people taking full depth cuts of 1/4" and even 5/16". I found that hard to believe but found that with lots of spray on wd40 from an aerosol can and a slow feed that it worked just fine. I was surprises and pleased to find that.---Brian
  5. May 16, 2018 #5
    xpylonracer
    xpylonracer
    xpylonracer
    Dec 23, 2010
    218
    51
    Make sure the workholding clamps are very secure before cutting and make sure you are not "climb" cutting or you may/will get a jammed cutter.
    xpylonracer
  6. May 16, 2018 #6
    deverett
    deverett
    deverett
    deverett
    Sep 6, 2007
    970
    167
    Just curious - are we talking about slitting saws with no side clearance or very thin side and face cutters? Like Brian, I find it hard to believe that full depth cutting is possible, particularly on some of the thinner saws, say 30 thou. or less which I have used on quite deep cuts. I know that one cut gives less wear and tear on the teeth, but I just can't bring myself to cut 1/4" or 5/16" deep in one pass with the possibility of the teeth becoming clogged.
    The Emerald Isle
  7. May 16, 2018 #7
    Mechanicboy
    Mechanicboy
    Mechanicboy
    Jul 10, 2013
    525
    181
    Use kerosene instead WD-40 when cutting in aluminium.
  8. May 16, 2018 #8
    WOB
    WOB
    WOB
    Sep 12, 2013
    60
    18
    WD-40 is mostly kerosene.
    WOB
  9. May 16, 2018 #9
    XD351
    XD351
    XD351
    Feb 17, 2015
    167
    29
    True but plain kero is cheaper to buy in bulk . I have heard of people using denatured alcohol or metho on aluminium as it evaporates and doesn't leave gunk oily gunk on the machine .
  10. May 17, 2018 #10
    Johno1958
    Johno1958
    Johno1958
    Sep 19, 2015
    109
    39
    Thanks everyone.
    Looks like I'll be using some scrap and doing some test cuts. Almost makes me want to make/buy a flood coolant system but I really have been getting a long quite well without one (until now?). The majority of the material is 6061 aluminium but the head is 6060 and is gummy stuff so keeping the blade clean will be a challenge. I don't think I'll break a blade but I may stall out my machine.
    I'll have to research metho as a cutting fluid but I also have heard of this. Sounds like a fire hazzard :hDe:
  11. May 17, 2018 #11
    Lakc
    Lakc
    Lakc
    Aug 22, 2009
    985
    42
    Invisible fires are not my idea of fun :/
    I can get water mix cutting oil cheap here so that is what I use in a decent sized pump oil can. Plenty of lubricant, just as the teeth enter the part.
    [​IMG]
    Johno1958 likes this.
  12. May 17, 2018 #12
    bazmak
    bazmak
    bazmak
    BAZMAK
    Dec 12, 2012
    1,969
    1,105
    Full depth of cut with very fine feed and continually backing off
    There is no way you should be anywhere near stalling the machine
    Just take your time ,back off the cutter ,stop the machine and clear chips etc
    CONTINUOUSLY.This job should take 2/3 times longer than you think but
    well worth the effort and not jamming the cutter.Run a diamond file over the teeth of the cutter before you start
  13. May 17, 2018 #13
    Wizard69
    Wizard69
    Wizard69
    Mar 9, 2013
    1,097
    213
    I haventdone a lot of slitting saw cutting eo cant offer much more than already has been offered. So here it goes.
    First understand how your saw is ground. Many are hollow ground which limits depth of cut.
    Second try to think of this saw as being similar to a bandsaw blade where ideally you have at least 3 teeth engaged in the cut. At least that worked the few times ive done it.
  14. May 17, 2018 #14
    XD351
    XD351
    XD351
    Feb 17, 2015
    167
    29
    Some people don't run the locating key so if it jams up the blade can spin in the holder , i tried this last time i used my slitting saw as i had to run the blade right out on the end of the holder to get clearance over the chuck so the locating key couldn't engage the slot in the saw bore and everything went well .
  15. May 17, 2018 #15
    DICKEYBIRD
    DICKEYBIRD
    DICKEYBIRD
    Sep 28, 2007
    653
    45
    I just did a bunch of full depth cutting of 1/2" & 3/4" aluminum yesterday with my X3 mill. I use a 3 3/4" 24 tooth carbide tooth blade that's originally made for cutting wood in a battery powered trim saw. Until a few weeks ago I had always cut a 1st pass @ .100" depth then successive cuts @ 1/4" to 3/8" with 300 to 350 rpm, conventional cutting direction. It was always a feed by hand, hold your breath job trying to avoid chips clogging the gullets & jamming.
    After switching to climb-cutting, I run @ 600-650 rpm & use the power feed turned up to half to 3/4 speed, depending on stock thickness with an occasional spritz of water-soluble coolant. It's absolutely amazing how much difference there is when you blast the chips out behind the cut instead of trying to keep them from clogging up the works in front of it. I woud expect the same results with HSS blades run a bit slower. Try it, you'll like it!:thumbup:
  16. May 17, 2018 #16
    werowance
    werowance
    werowance
    Sep 2, 2011
    332
    102
    wow, everytime I climb cut with my slitting saw, things get mangled, jammed pushed out of the vice etc. it never ends pretty for me. bent saw blades even... what type of slitting saws /arbor are you using? not that I am an expert by any means and still learning my self is why I am asking.
    the climb cuts I made were actually by accident by starting on the wrong end of the part....:wall:
    xpylonracer likes this.
  17. May 17, 2018 #17
    Charles Lamont
    Charles Lamont
    Charles Lamont
    Mar 24, 2011
    473
    120
    Ideally, if the slitting saw is clamped to the arbor by a bolt, run so that if the saw tries to jam the bolt will losen. However, this normally means running in reverse, which you machine may well not do.
  18. May 17, 2018 #18
    DICKEYBIRD
    DICKEYBIRD
    DICKEYBIRD
    Sep 28, 2007
    653
    45
    The blade mentioned above is mounted in a homemade 3/4" straight shank arbor.
    [​IMG]
    I have the gibs set with a little drag on X & I lock down Y & Z before starting a cut. Perhaps your mill is set up on the loose side? I kid you not, my X3 has some wear on it but climb sawing works great!
  19. May 17, 2018 #19
    werowance
    werowance
    werowance
    Sep 2, 2011
    332
    102
    wow, that's a wood saw blade for the little battery powered deals isn't it? I guess since its carbide itll cut metal just like it would wood.
    mine is actually a lathe mill combo. which I regret going that route, but yes the mill head is on a post that can work its way loose and swing around and well just about everything can vibrate loose on it.
    what I normally use is little bitty about 1.5 to 2 inch dia saw blades about .030 or thinner. slitting little screw heads or slitting to a hole to make a clamp or something.
    but that blade is a beast.
  20. May 18, 2018 #20
    bazmak
    bazmak
    bazmak
    BAZMAK
    Dec 12, 2012
    1,969
    1,105
    The woodworking carbide insert blades as shown work best in aluminium
    at higher speeds ,feeds etc and go down to about 3mm thickness.True slitting saws go much thinner,are carbon or hss and usually have no kerf so have to be run slower with more chance of jamming.We seem to have been discussing 2 different thing here. If your slots are at least 3mm w then use the carbide
    woodworking saw.I have used both in alum
Share This Page
