Hello All,
I am getting back in to model engine building after a 5 year break while life got in the way. I have built a few steam (air) engines, a die filer and other assorted beginner projects with success.
I am picking up where I left off which is building Rudy's Pioneer Engine and I am stumped on the valve which are steel, .500" diameter head, .125" stem, 2.060" overall length. My problem is how to turn it , that small a diameter, that short of a distance I don't really have room to take advantage of a follow rest. The only answer I can come up with is to make the valve head and then press fit the stem into it, using drill rod for the shaft.
Any ideas or insight would be appreciated.
Thank you
Bluzzin
Thank you
Bluzzin
