- Dec 5, 2009
- 510
- 47
This is a weekend project job I did for a client, He wanted his very old craftsman heavy duty belt sander repaired, it had an unbearable amount of vibration, and he asked if I could take a look at it, and see what can be done.
Once I showed him the problem, I suggested a repair I could do for it, using my hobby benchtop machineshop tools, and he agreed to it.
Video part 1
is the problem revealed and the solution to fix it, and the start of diisaembling the sander to get to the motor shaft
https://youtu.be/wDy6BdjySkE
video part 2
is mainly the drawing up on my drafting board the parts that need to be made, including a fixture, and the actual part for repair.
https://youtu.be/lUyX8QbKLFI
video part 3
is where I',m making the alignment fixture that will be used along the repair and assembly of the machined part.
https://youtu.be/If4nfJzOqOc
video part 4
is the machining of the new part that will replace the broken one in the sander.
https://youtu.be/V4bPOgV5Q_M
video part 5
in this video I'm using the shaft fixture we made earlier, to align the fan cage and the bearing flange part on the lathe to temporarily glue in place , then start setting up my rotary table, and aligning the whole fan assembly on the table, getting ready to drill the rivet holes.
https://youtu.be/YLrb-2q-p_A
video part 6
in this video I have the rivet holes drilled, then I rivet everything together to finish the part into a complete squirrel cage fan, then install it back on the sander and run it to check for any excess vibration.
https://youtu.be/_ApEoz-a708
have fun in the shop...
Video part 1
video part 2
video part 3
video part 4
video part 5
video part 6
