Lubrication for open geared Metal Lathes
Discussion in 'Machine Modifications' started by JimDobson, Jun 13, 2019 at 7:03 AM.
  1. Jun 13, 2019 at 7:03 AM #1
    JimDobson
    JimDobson
    JimDobson
    Sep 11, 2013
    68
    28
    South Coast of New South Wales Australia
    I know everyone has there favourite product, but CRC TAC-2 for me is just absolutely brilliant and lasts and lasts.
    Really quietens down the gear noise.
  2. Jun 13, 2019 at 12:47 PM #2
    Cogsy
    Cogsy
    Cogsy
    Well-Known Member Staff Member Global Moderator
    Jul 30, 2012
    2,472
    713
    Gender:
    Male
    Perth, Western Australia
    TAC-2 is a good product for open gears or chains, any of the decent motorcycle chain lubes work fairly well also. You've reminded me that I need to spray a bit of lube around next visit to the shed.
  3. Jun 13, 2019 at 12:56 PM #3
    JimDobson
    JimDobson
    JimDobson
    Sep 11, 2013
    68
    28
    How often do you pump oil in those ball bearing nipples (if you have them in your lathe) Al ?
  4. Jun 13, 2019 at 1:01 PM #4
    Cogsy
    Cogsy
    Cogsy
    Jul 30, 2012
    2,472
    713
    Gender:
    Male
    That's a tough question. Probably not as often as I should, but more like when I notice the visible surfaces are looking a little dry. I know when I do give them a squirt everything seems to run smoother and easier so definitely too long between lubes. At different times of the year I can go months without getting out to the shed at all so I don't have a set schedule like I should.
    JimDobson likes this.
  5. Jun 13, 2019 at 9:33 PM #5
    deeferdog
    deeferdog
    deeferdog
    Well-Known Member Project of the Month Winner
    Mar 23, 2014
    253
    225
    Gender:
    Male
    Gold Coast, Australia
    Because I'm near the ocean and rust is constant reminder of its proximity, I spray all my machines with a mixture of kerosene and engine oil. The stuff works its way into every nook and cranny and keeps everything lubricated. I do this on a very regular basis.
  6. Jun 14, 2019 at 12:57 AM #6
    JimDobson
    JimDobson
    JimDobson
    Sep 11, 2013
    68
    28
    Thanks AL.
  7. Jun 14, 2019 at 12:58 AM #7
    JimDobson
    JimDobson
    JimDobson
    Sep 11, 2013
    68
    28
    I live right next to the ocean as well. I have never tried kero and engine oil but will give that a try on some items that I have outside under a lean to that I always have a problem keeping rust away from.
  8. Jun 14, 2019 at 5:09 AM #8
    DJP
    DJP
    DJP
    Dec 7, 2012
    466
    113
    Kerosene and Automatic Transmission Fluid is my home brew lube for cleaning and rust protection.
  9. Jun 14, 2019 at 10:33 AM #9
    XD351
    XD351
    XD351
    Well-Known Member HMEM Supporter
    Feb 17, 2015
    303
    58
    I use lanotec and i can attest that it works well , when you uncover your lathe and it looks like it has just had a shower but not a speck of rust on it you know you are onto a good thing ! Only donside is if left on long enough it goes waxy and is a bit harder to get off but some cheap spray degreaser gets it off relatively easily.( i buy in bulk from supacheap or repco when on special ) .
    blanik likes this.
  10. Jun 14, 2019 at 2:56 PM #10
    fcheslop
    fcheslop
    fcheslop
    Apr 7, 2010
    721
    147
    The land of the Prince Bishops
    For open gears I tend to use motorcycle chain lube or what evers to hand working on the principal any oil is better than none
    For general rust proofing Tooling spray does a good job for long term protection Outside Storage Protection Spray works well but a swine to get back off
    https://www.moleroda.com/product/mould-protection-spray/
  11. Jun 15, 2019 at 4:20 AM #11
    JimDobson
    JimDobson
    JimDobson
    Sep 11, 2013
    68
    28
    Thanks for the link, I have some outside tools in a lean to (and I'm right on the ocean) that that spray would be excellent for.
  12. Jun 15, 2019 at 6:05 AM #12
    Cogsy
    Cogsy
    Cogsy
    Jul 30, 2012
    2,472
    713
    Gender:
    Male
    Jim - the Lanotec product that XD351 uses should also be a good choice for rust-proofing stored tools and is not overly difficult to remove as far as I know. It's a lanolin based product so it's not only good on your machines but on your hands as well (lanolin is the oily stuff sheep make and keep shearers hands in good condition).
  13. Jun 15, 2019 at 6:26 AM #13
    JimDobson
    JimDobson
    JimDobson
    Sep 11, 2013
    68
    28
    Al I have a couple of litres of Lanotec antifoul left over (I don't use it on my boat anymore) I might give that a try on some of my outdoor tools and machinery.
  14. Jun 16, 2019 at 12:16 PM #14
    clockworkcheval
    clockworkcheval
    clockworkcheval
    Dec 5, 2017
    11
    3
    Motor cycle chain lube sounds like an effective option; thanks. Part of my machines, mostly the woodworking variety, live in the back of an open shed. I fight the rust with wool grease. Apparently Australian sheep farmers noticed that steel posts do not rust where sheep use them as rubbing posts. It works! It comes over here as rather solid grease, so I mix it 50/50 with light oil for easier application.
  15. Jun 18, 2019 at 1:17 AM #15
    lennardhme
    lennardhme
    lennardhme
    May 26, 2009
    170
    33
    Occupation:
    Retired Electronics Engineer & Instrument maker.
    Narracan. Australia
    My anti rust solution is to cover my machinery with a woolen blanket [cheap from an op shop] . I spray the inside with Lanotec, one of my favorite products, & that seems to emit a "mist"that coats everything & keeps it in top nick. I live in a wet mountainous area & find this is a great solution.
    cheers
    Lennard.
  16. Jun 18, 2019 at 4:18 AM #16
    clockworkcheval
    clockworkcheval
    clockworkcheval
    Dec 5, 2017
    11
    3
    Ah, I checked. Same stuff. Lanotec is based on wool grease.
  17. Jun 18, 2019 at 4:24 AM #17
    JimDobson
    JimDobson
    JimDobson
    Sep 11, 2013
    68
    28
    Its great for cracked hands and heels as well :)
Share This Page
