- Feb 17, 2008
- 2,326
- 440
Well, it's not going to run today.
First off my ride to Thanksgiving dinner will be here shortly and I don't expect to be back until late.
But more importantly, I have something screwed up on timing. It's too early to tell for sure if it is design or I screwed up machining. But it is at least consistent in that it is the same on both cylinders. At bottom dead center, I have a small over lap where the intake, transfer and exhaust are all connected. So, no suction on the intake. Determined by blowing into the venturi while turning the engine over. I just make up a connector to replace the carb with a tube connected to it so I can play. I will put a disc on the crankshaft so I can measure what is opening where so I can try to deduce what is happening before I tear it down.
I will also go over all the timing calculations for the ports so see what I can find out there. If nothing shows up on the design, then it will be time to tear it down to see what is happening. That should keep me busy tomorrow, and then a day or two (optiminst) to make new parts to correct the error.
So, although I did not plan it that way, we will all get a lesson in trouble shooting a new design.
I still have faith that it will run soon.
Gail in NM
Gail in NM
