Hi
I am buying a new lathe (Al 336d hafco) and wanted to know where to buy a good set of lathe tools (I am in NSW Australia) also what tools will I need as the new lathe does not come with any?
Thanks Matt
Matt. Nice lathe. Hare and Forbes where your lathe comes from have a couple of carbide insert tooling kits. One has a left hand and right hand tool and a boring bar with 10 inserts which is pretty good value on special.
http://www.machineryhouse.com.au/L450 Don't get the 7 piece kit as you can't buy the inserts individually, only in a kit of all kinds and they are not very good quality. Ask me how I know? I also bought a thread turning kit from them (with inside and outside tools) because I wanted one without waiting for an overseas order to arrive.
The listing for your lathe says it comes with 4 tool holders for the QCTP. Hopefully, one of them will be for a parting blade so grab a HSS steel parting blade for it which will get you going for under $20. Eventually I bought an insert parting blade and holder
You probably will need a drill chuck for the tailstock (and a couple of centre drills). H&F will have them too. Get a chuckless one. 12mm rather than 16mm is probably the way to go as they are more compact and most larger drills are reduced shank anyway. H&F will pair it with a shank to match your MT3 tailstock.
A live centre (as a kit with different ends or on its own) would also be handy.
A lot of us buy tooling from CTC tools in Hong Kong
http://www.ctctools.biz/servlet/StoreFront
Good quality and a set of 10 inserts is about $40 instead of $100. I save up and every now and again lash out with an order for a few hundred dollars to make the freight worthwhile. You can probably buy additional tool holders to suit from them too.
An oil can and a 4 litre bottle of hydraulic oil (H&F have this too)
So in summary, a turning kit, a drill chuck, a HSS parting blade and some centring drills is probably all you need to get going then stuff will breed like crazy over time!
