Well, after being laid off from work I turned to the shop to pass the time away until employment would come around again and I settled onto this engine. I purchased the drawings about 17-18 yrs. ago and always had it in the back of my mind (I have a mind?) to build. The drawings were inked by a Bob Smith of Scribe and Co. based out of San Diego, CA. The plans are very well drawn and I have not found any errors whatsoever in my examinations of them. However, not being one to leave anything alone, I have made some major changes from the original plans and have more in the works. This engine will become a four column, double acting, upright, with a bore of 1.000" and a stroke of 1.800". It will sport a Stephenson valve gearing arrangement that will be changed by a small handwheel. (at least that is my plan) The brass flywheel is 3.000" in diameter and is 1.250" in width. The original plans called for narrower flywheel than shown and did not call for the outboard bearing block that I added in order to support the extra weight. The crankshaft is a piece of .250" silver steel riding in bronze bushings. The original merely had it running in square aluminum bearing blocks. The next step will be to machine the cylinder and columns and fabricate the bottom cover. There's plenty more to come so stay tuned.
