Knucklehead Plans
Discussion in 'Plans' started by Draw-Tech, Jun 28, 2014.
Help Support HMEM by donating using the link above.
  1. Jun 28, 2014 #1
    Draw-Tech
    Draw-Tech
    Draw-Tech
    Jan 26, 2012
    150
    90
    Hi all
    Almost done, a little work on the oil system, throttle linkage, and then to build. If you want to see the guts, download dwf viewer at autodesk.com its free, and if nothing else you can play with the model. I am using the flywheel from my 4 Cylinder, to give some momentum, and cooling.
    PS The file is to big 4 MB if you want the file drop me a PM
    Jack
    Draw-Tech
  2. Jun 28, 2014 #2
    hedgehog
    hedgehog
    hedgehog
    Active Member
    Jan 16, 2009
    30
    7
    very nice drawing there. i would like to follow the build if you post it
  3. Jul 24, 2014 #3
    Draw-Tech
    Draw-Tech
    Draw-Tech
    Jan 26, 2012
    150
    90
    Hi All
    Been working a lot on the Cam and push rods, going pretty good, all I Have to do is time the valves to the cam. Got the gears figured, added a starter motor with brushes, to convert to a generator once the motor is running. Included a dwf file in the zipped file,to view the model, download the dwf viewer from autodesk.com look on the first page at the lower left, as soon as I have finished I will post the full dwf. To view, and measurements can be taken. (Warning) I change things a lot, so no guarantee, and no promises. This is not the final drawings. If anybody has a chart to show the cam angle between the (4) cams, it would help a lot. By the way the flywheel diameter is 2.8"
    Jack
    Draw-Tech
    View attachment Knucklehead_V-Twin_Gear_Trane.pdf
    View attachment KH_Gears.zip
    Chiptosser, hedgehog and Rozlo like this.
  4. Jul 28, 2014 #4
    necchiom
    necchiom
    necchiom
    Jan 6, 2009
    72
    14
    With compliment! Nice project.
  5. Jul 28, 2014 #5
    Swifty
    Swifty
    Swifty
    Mar 6, 2012
    2,253
    812
    Very nicely drawn, a few prints of that framed would make any workshop look great.
    Paul.
  6. Jul 29, 2014 #6
    Draw-Tech
    Draw-Tech
    Draw-Tech
    Jan 26, 2012
    150
    90
    Hey All
    Updated oil system
    Jack
    Draw-Tech
    hedgehog, Rozlo and minh-thanh like this.
  7. Jul 29, 2014 #7
    johnmcc69
    johnmcc69
    johnmcc69
    Dec 5, 2011
    152
    15
    That's some nice work Jack!
  8. Feb 4, 2018 #8
    Cabbagestack
    Cabbagestack
    Cabbagestack
    New Member
    Aug 28, 2016
    1
    0
    I see a few jpegs but no plans. What's the deal ??
  9. Feb 4, 2018 #9
    Cogsy
    Cogsy
    Cogsy
    Well-Known Member Global Moderator
    Jul 30, 2012
    2,036
    576
    Gender:
    Male
    They're available at THIS LINK
    ACHiPo and minh-thanh like this.
  10. May 27, 2018 #10
    john williams
    john williams
    john williams
    New Member
    May 20, 2018
    4
    0
    hi ,is there an issue with the above as it just come up with a error message
  11. May 30, 2018 #11
    Cogsy
    Cogsy
    Cogsy
    Jul 30, 2012
    2,036
    576
    Gender:
    Male
    The new forum has a different link so the old one is broken, try THIS LINK.
  12. May 30, 2018 #12
    minh-thanh
    minh-thanh
    minh-thanh
    Dec 29, 2016
    189
    141
    Very nice drawing .
  13. May 31, 2018 #13
    john williams
    john williams
    john williams
    New Member
    May 20, 2018
    4
    0
    hi cogsy many thanks for the info,have got them
    john
Share This Page
