Kerzel Hit and Miss
weez
Project Of The Month Winner
I finally got started on my first IC engine, the Kerzel Hit and Miss. Here is the start of the cylinder body.
First I milled a chunk of aluminum to size. I used my new boring head as a flycutter and it worked very well.
I drilled out the bore with a 1/2 inch drill, then a 3/4 inch endmill, and finished up with the boring head.
Drilled and tapped the head bolt circle.
I didn't notice that I forgot about the counterbore until I had taken the piece out of the vise. So I had to reindicate the piece to finish the counterbore.
After flipping it on the side, I milled the pocket for the cam slide bearing.
And finally drilled and tapped the holes on this side.
  • Like
Reactions: gus
This is the setup I used for the undercut for the water passage. I mounted the boring bar upside down and cut on the backside of the bore to make it easier to see.
Hi Weez,
you are making great progress.th_wav Will be following your thread.
Kerzel is a good engine to build but I have a long list to dream on. So many engines to build and so little time.
Here is the machining of the water reservoir. First I milled out the square portion with a 3/8 inch endmill.
Then machined the round undercut with the boring head. I had to grind some clearance above the carbide. (Sorry for the blurry picture).
Got the rounding done on the cylinder body. After centering the rotary table on the mill I indicated on the bore and clamped it down using a threaded rod and washers. I installed some clamps to use as stops for when the part gets flipped over so that I don't have to re-indicate. Using a 3/4 inch end mill, I machined away the majority of the radius to a depth of .655".
Then finished up with a 3/8 inch ball mill.
I flipped the part over and rested it against the stops and clamped it down.
Using a 3/8 inch ball mill, I milled out the bottom radius to a depth of 3/4 inch.
Then milled the top radius to a depth of 1/8 inch.
And milled away the rest with a 1/2 inch end mill.
Here is the detail work on the top of the water reservoir. First using a 3/8 inch ball mill.
Then finishing with an end mill.
And finally the finished cylinder body. I think this is the most complicated piece that I have made to date. I am very pleased with how it turned out. Hopefully it is all downhill from here on this build.
Lovely job indeed. I remember thinking at the time that it was the most complex part I had made. Good luck with fitting the cylinder and getting it water tight. I remember that I slathered mine with green Loctite, started out with an arbor press, stuck half way in, and finished with a 4 pound hammer!!---Brian
Thanks Brian. Have you run yours without water? In the drawing notes David Kerzel states that it doesn't need water and will only get to 120 deg F without.
No, I always run mine with water. David Kerzel is probably right, but I am an old guy and I well remember using hit and miss engines 50 years ago, and we always ran them with water. Of course, they were working engines, driving buzz saws and irrigation pumps, so they probably generated more heat. I can remember running my Kerzel hit and miss out in my main garage in the wintertime on an endurance run, and after an hour of running there was a visible column of steam rising into the cool air from the water reservoir, which I thought was really neat!!!----Brian
I share the same sad story with a DIY hydraulic cylinder cap threaded into the cylinder. The lesson is " Check Loctite No'' before use.
Now Retrofitting the Deep Sea Swivel-Base/inclinable Rod Holder for Feb 22---28 Burma fishing trip. Now prepping my mind to finish up the H&M after Burma.
Hi Weez
Great looking cylinder, I remember going through all those steps, except I bored my cylinder block in the lathe, I added (2) O-Ring Grooves, and silicone O-Rings, to prevent leaks.
Jack
Draw-Tech
Hi Weez,
Water Jacket very well done and finished. For the finishing cut,did you use very sharp end mill?
Thanks Gus. For the finishing cut I use a standard cheap end mill. I make my final depth of cut about .005" deep and feed really slow.
Hi Weez
Jack
Draw-Tech
Thanks Jack. I would have bored mine in the lathe, but my 4" chuck was too small. I checked out your engine and it looks great. Did you get it running?
Now on to the base. First drilling and counter boring all the bolt holes.
Because of lack of enough Z axis I couldn't use the vise and had to come up with this setup. I almost made a huge mistake and had it all set up with the bottom of the base facing out. I noticed it right before starting to cut. Glad I caught it but still didn't like having to re-indicate everything for a second time.
Then a 3/8" ball mill to finish the piece.
And here is the completed base.
