A few years ago when they came out I made on but using it on the "nod"
axix is even worse than just a single indicator to figure out the direction to
move. With practice it should only take a few minutes with a single
indicator with about a 6" radius swing and a big truck disc brake rotor . I do
the ones at school every now and then .
...Lew...
I don't understand how one of these is better than swinging an indicator in the spindle. Been doin' this for 30 years and I've never seen one of these used.
You still need to swing it around at least once to calibrate both indicators. I can do that with a single indicator. Just set the indicator on zero, turn indicator 180 degrees on spindle, note the difference and move the head half of the indicated reading. Double check by turning the indicator 180 degrees again.I don't think it could be better. Maybe a bit quicker though?
