- Aug 18, 2008
- 343
- 134
I was doing some research on computer radiators for my latest engine project. I am aware of galvanic corrosion of dissimilar metals in automotive cooling systems and being a bit anal, decided to look in to it a little further. The link below is from an overclockers (guys that push computer graphics beyond design limits requiring liquid cooling of processors) website. It gives a good description of the problem, but goes a bit too far into the solutions. These guys are more anal than I am.
Suffice to say, the problem is real, but the solution is fairly simple. Use 50/50 premixed automotive (ethylene glycol type) antifreeze in any model engine cooling system with aluminum and any other metal in the coolant path. The corrosion inhibitors in automotive antifreeze are made for this problem, but the inhibitor concentrations are based on using a 50/50 mix. Do not use higher concentrations of straight antifreeze as the heat transfer will be significantly reduced.
As I see it, the potential problem for model builders is that even though a cooling system is drained, it remains "wet" inside for a long time. Galvanic corrosion can continue until all water (electrolyte) is gone. Hence galvanic corrosion can continue long after the coolant is drained while the engine sits idle on the shelf. The use of the proper antifreeze solution will inhibit any such corrosion whether the system is drained, or left wet.
Since we tend to use much heavier metal thickness in models than used in real life machines, many would say this is a moot point. However, I believe the model builder's art should be preserved properly, and to the best of our ability.
Jeff
Note: Ethylene glycol is highly toxic to humans and pets.
http://www.overclockers.com/pc-water-coolant-chemistry-part-ii/
Jeff
