- Aug 18, 2008
- 343
- 135
[FONT="]This is my finished 25 hp Bates & Edmonds 17kw model electric plant in 1/8th scale. These unusual looking OHV engines used eccentrics and pull rods rather than cams and push rods. This valve arrangement was known as the alligator link valve motion. The full size engines used two built in adjusting features to time the valves. These same features could not be duplicated in the model at this scale, but other provisions were incorporated to make timing manageable. The eccentric and valve depressor lever over-travel on the model requires compromises in valve lift, and duration each influencing the other. Confusing at first, but there is an orderly method that works. Fortunately slow speed engine valve timing and valve lift isnt that critical, and the engine does well at slow speeds.[/FONT]
[FONT="]The prototype B&E engine was found at the Coolspring Power Museum. It was surveyed and photographed and Doug Kelley did the engine build drawings. The model was fabricated from aluminum, brass and steel bar stock. Bore x stroke is 1.00 x 1.18. The model has a wet sump using splash lubrication as did the real B&E engines. The compression ratio is about 5.5:1, and it runs smoothly at 550 RPM with, or without load. The crankshaft is a 360[/FONT][FONT="]⁰[/FONT][FONT="] type (two up, two down) with counterweights and ball bearing mains. The S/S ignition is a single coil waste fire type. The fuel system is a modified 3mm self-compensating RC carburetor using propane fuel. The model features follow the prototype fairly closely, but a few exceptions were necessary at this scale.[/FONT]
[FONT="]A 1918 dated piece of B&E electric plant literature shows Garwood Electric Co. DC generators were used by Bates & Edmonds on their full range of 5.5 to 27kw DC electric plants. DC electric plants were popular in that era in rural and grand hotels attracting guests wanting to experience the modern marvel of electric illumination. The direct connected Garwood model generator was fabricated using a rewound 12 pole alternator stator core. It uses permanent magnets for excitation and provides a regulated 12vdc output. The generator output is 3 amps at 12vdc at a speed of 500 RPM. It is capable of higher output with a larger regulator, but the current rating and regulator suits this engine/generator combination nicely. The generator is a 2 bearing type. It hums a bit due to the magnets and slow speed, but does a good job.[/FONT]
[FONT="]The modular switchboard, metering, and radiator idea was seen in another model builders work. It worked out very well here, and incorporates a lot in a small footprint. The cooling system uses a computer radiator, expansion tank, and generator powered thermostatically controlled fan which is rarely needed at light load. [/FONT]
[FONT="]
My video skills are still lacking, but you can get the feel for how it runs. The engine is actually quieter than the generator.Hope you enjoy.[/FONT]
[FONT="]Jeff[/FONT]
[FONT="]https://www.youtube.com/watch?v=52cj8px3GSA[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
[FONT="]
[FONT="]Jeff[/FONT]
[FONT="]
[/FONT]
[FONT="]
[/FONT]
