Ok, seriously newbie question here:
How do I drill/machine a perfectly perpendicular hole? I'm putting a 3/8" hole in some 3/8" aluminum. I used a 1/4" drill, followed by a 3/8" drill. The vise is a machining vise that I used on my drill press, which checks out to be square.
The first time I tried I got a hole that was enough off perpendicular that I think I had cocked the piece in the vise.
The second time I tried I checked everything square and it came out close, but not perfect.
Should I used the mill instead of the drill press? Can you mill a hold more accurately with an end mill? Should I plunge cut with a 1/4" end mill and follow with the drill? Plunge cut with a 3/8" end mill?
I don't have a reamer this small, but I'm not sure that would help in the accuracy of the hole.
Anyhow, sorry for the newbie ignorance, but I appreciate the experience here in the group!
Gary
Gary
