Bill S said:
I found this in a pack of #1 drill bits and it begs the question, how are drill bits made? It looks as if it got fouled up in the manufacturing process. Are the slots cut straight and then twisted, as in twist drill. Or are they cut with the twist?
Nope, not fouled up due to the manufacturing process, that bit has been used and it has grabbed on the break out and then the flutes have unwound. Reason being, that the drill was not hardened correctly, or they have used inferior materials to make the drill bit. Better just chuck the rest of the packet in the bin and don't buy any more of that brand.
The easiest way to explain how most twist drills are made is that they start life as a large coil of black wire of the correct grade, this is sent through machines to straighten it out and then the blanks are cut to length.
Two ways of going about making them at this point, first way is to put the blanks through another machine that holds them at the end and then they are induction heated and then the flute is rolled in whilst it is hot, or they go into a machine that grinds the flutes into the blank.
Then into the centreless grinder to size them to what ever they need to be, then over to another machine to grind the relief into them, followed by the drill point being ground onto it.
Actually quite a few of these processes are very finely tuned, to make a twist drill the correct size, there is a lot more to it, than this simple explanation.
Had a 24mm drill of chinese origin do the same thing, you could have used it for a left hand drill after it unwound.
regards greenie
