homemade grinder tool rest
Discussion in 'Finished Projects' started by celsoari, Jan 7, 2018.
  1. Jan 7, 2018 #1
    celsoari
    celsoari
    celsoari
    from Brazil
    Nov 25, 2014
    32
    19
    my home made tool rest (audio in portuguese)
    [ame]https://www.youtube.com/watch?v=fB89qNN2gDs[/ame]
    greetins from Brazil
  2. Jan 7, 2018 #2
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    1,653
    384
    Muy Bien!
    Some time back, I bought the Veritas rest which is fine, then I bought the Acute tool and cutter plans from Eccentric Engineering which has a similar rest but can be more easily locked with Bristol clamps.
    What came out of the plans was a simple little jig to set- almost automatically, the angles for tool bits. I have already suggested the maths for this in earlier posts but whether anyone has got around to actual reading and then DOING it is one big imponderable.
    What appears here is the ability to slide lathe and end/slot drills by adding a pair of holders similar to the one designed by Arnold Throp of Dore Engineering and was sold as castings by Ivan Law as the Kennet
    It is far easier to set up than the Quorn- or so Mr Throp mentioned to me at an exhibition
    Cheers/Salud
    N
  3. Jan 11, 2018 #3
    Tad Wicks
    Tad Wicks
    Tad Wicks
    Feb 20, 2010
    23
    1
    Ótimo trabalho
    Eu também gosto da música Tad
    celsoari likes this.
  4. Jan 13, 2018 #4
    MUUTOR
    MUUTOR
    MUUTOR
    MUUTOOR
    Jan 21, 2014
    6
    1
    Parabens. Se tivesse algumas legendas em ingles talvez ajudasse os nossos amigos anglo-saxonicos. Abraco.
    Nice tool improvement by our friend of Brasil.
  5. Jan 14, 2018 #5
    celsoari
    celsoari
    celsoari
    from Brazil
    Nov 25, 2014
    32
    19
    Dear friends Muutor, Tad and goldstar31, thanks for yours coments
    ( obrigado pelos comentários amigos)
    Celso Ari
    from Brazil
  6. Jan 14, 2018 #6
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    1,653
    384
    Pleased to help!
    Two points are probably constructive.
    The first is that you could continue on your work tables with the Eccentric Acute tool grinder.
    The second is that Arnold Throp put an additional slide on top of the grinding rests and then added a choice of three work holders to do,
    1. lathe tools
    2. ends of end mills
    3. grind slitting saws
    His design was called the Kennet.
    This is no longer available but could easily be copied in much the same way as the Worden which is available as a kit or kits from Hemingwaykits in England.
    Apart from this--do you have a better choice of music, please?
    I hope this adds to your information.
    Norman
  7. Jan 16, 2018 #7
    JCSteam
    JCSteam
    JCSteam
    Nov 30, 2016
    357
    61
    Very nice grinding rest, having just got a grinder up and running I could do with something like that myself. Loved the video too, nicely edited ;)
  8. Jan 17, 2018 #8
    goldstar31
    goldstar31
    goldstar31
    Feb 20, 2010
    1,653
    384
    Probably getting a cheap secondhand arc welder and learning how to use it would really extend what can be done with limited tools.
    I may only use my MIG( Metallic Inert Gas welder using the Active gas technique) welder once in a blue moon but I'd be lost without mine.
    ( we must get together when the weather gets warmer, eh?)
    Norm
    JCSteam likes this.
Share This Page
