High Temperature Gasket Material
Philjoe5
I use a moldable gasket material on the hot end of Stirling engines that has withstood the temprature of a propane torch for several minutes. It's branded "Permatex' Ultra Copper High Temp RTV Silicone. It's rated to 700 F (intermitten). It's fairly thick. I apply it to both mating surfaces, let it get tacky then fasten the two surfaces. Others on this forum have pointed out that it will flow when the mating parts are fastened together and I have also observed this so use is sparingly and let it set before fastening. I buy it at auto parts stores in the USA.
Phil
Hi ,I was going to mention that stuff, it's known as Hylomar in the UK, it's good but you need to get inside to clean up the stuff that squeezes out ,if not ,it can cause problems, perhaps some of the guys here might say it would be cheating!, but it has it's uses....Giles
