I used this product to quarter my loco wheels about 3 weeks ago. I thougbht I had them quartered right alas no joy. I decided to try and get them apart by whacking the end of the axle with the wheels supported close to the axle. I was afraid it wouldn't work because the I thought it was supposed to be permanent but it worked to easily actually.
On examination of the axles I discovered there was only about 1/4 in of residue on the axle and it felt slightly sticky. I had cleaned the axles and wheels with acetone before applying the locktite to stick them together. I applied a band of locktite around the axle and stuck them together. There was excess locktite on the outside of the wheel/axle and the inside that I had to clean off.before it set up.
This stuff is supposed to fill gaps up .007 and have shear strength of 3000 psi. Fit on my axle /wheel is less than .007, and is used for Bearings, bushes, anchoring studs, valve guides ect.
I used a 3lbs small sledge to whack the axle end with a steel punch. The hammer had a handle of about 14 in. No damage to axles or wheels.
Is this stuff unsuitable for this job or do you think I messed up some where along the line.
Ron
Edit; Only one axle had a 1/4 in band of residue. The other 2 had full coverage on the wheel land on the axle .
