Hi
I fly model aircraft using four stroke glow engines (bought, not home made).
Good quality engines run well on 20% fully synthetic oil, 15% nitromethane and the remaining 65% in methanol. Carburettors for Japanese, O.S. make, four stroke glow engines are set to take the above percentages from the factory.
The nitro offers easier starting, a good idle and easier throttling, while the synthetic oil prevents the problem of discolouration and smell that is a product of using castor based oil.
Fuel with 20% synthetic oil and a nitro content of between 5% and 30% is readily available from RC flying shops in most countries as it is recommended for most well made Japanese glow engines.
It is crucial not to run the engines too lean and to run them in with periods of very rich running and moderately rich running for an hour or so until they will instantly throttle up to full revs and maintain high revs without hardening off. Bear in mind they are air cooled, need the correct size propeller, firmly attached with a second locking nut, being four stroke and don't take kindly to long periods of use on the ground. They will also kick up debris and loose material close to them, particularly behind the propeller. They should also be firmly attached to something heavy to prevent them moving around when operating.
A four stroke .70 glow engine with a 13" prop will easily develop 7500 revs, pull an 8 pound model into the sky and is a lethal weapon if not handled correctly - good luck!
The glow plug needs a 1.2volt battery for starting.
kind regards
Peatrich
