B
Bogstandard
Guest
I thought I would show you the backroom stuff that I do, the reason for me going quiet for a while, instead of all my pestering about. Making engines for other people does require a little more care, it is OK to have a few scratches and bumps on your own, but when it is for someone else, it has to be as near perfect as possible. Also because a lot of the parts are true custom pieces, it isn't feasible to make any extras, like if I was making a quick batch production, the time wasted could not be accountable, so if you make a mistake on one piece and rectify it, the other pieces have to be rectified in the same way to make them all the same. So the thing is, don't make mistakes.
I did a build on finger engines last year, and the basic dimensions are taken from that, but because I have free reign on the new design, I will modify the parts as needed, but still sticking to the dimensions.
http://www.homemodelenginemachinist.com/index.php?topic=862.0
I have already started on one of the major parts and turned it into a bit of a post.
http://www.homemodelenginemachinist.com/index.php?topic=1809.0
There are four basic major parts that need a good dose of looking at to give it a bit of pizazz. The flywheel, the conrod, the crank and the finger treadle. The plate work is fairly easy, just a quickie reshape and all will be OK on that score.
So here is as far as I have reached. The flywheels have been trued up perfectly and have had the centres glass bead blasted. The cranks are now shaped and built up to what I want them to look like. The rear standards are stuck together with double sided tape and are rough cut to size, I have drawn out on the plates what I want them to eventually look like.
This second picture shows the contrast produced by bead blasting the flywheels. Once all the work is completed, the flywheels will be sent back to the blasters to be chemically cleaned, just to remove any dirt from the blasted area.
None of these parts are yet polished. This is the preliminary stage where all the scratches and machine marks are removed. When polished the ali will end up looking like chrome and the brass will have a lustre that looks six inches deep.
The problem is I have only just over a week to get these engines finished. It doesn't help when a friend phoned me about an hour ago, for me to make him a new part for his classic racing motor cycle, by tomorrow midday.
