- Dec 28, 2008
- 548
- 4
I needed to drill a .047 cross hole in a .093 diameter shaft.
I already had a small fixture that I had used to bore the end of the connecting rod for my Poppin build. I decided to use it to make a temporary cross drilling fixture the other end of the connecting rod. I chucked a center drill in the mill and use it to mill a small V in the fixture. Then I mounted the connecting rod and stepped off 1.906 from the crank bore and drilled a hole nicely on center.
