Corliss Steam Engine (Coles Power Models)
Waiting for ordered tools, I start again.
The first two images are tests to validate the direction of rotation in self-tightening, speed and depth.
First, lathe machining, at a dimension + 0.03.
Then finish with a flat file + 800 grit paper, to the exact dimension with "0" clearance. This is to finish with fine lapping paste afterwards.
Then without disassembling the part, I transfer the chuck to the divider of my “13”
First open with a 20mm, 1mm thick disc cutter. As a reminder, I need 1.58 finished by 7 deep.
Then use a 1.5 end mill. Advance of 11mm/T and 2000rpm (maximum I can have)
At this moment, I have already cut 2mm deep and I assure you that I am watching like milk on the fire!!
Fortunately I only need two valves with an opening of 1/16"
LeZapView attachment 154510View attachment 154511View attachment 154512
Looking really good! Good plan!
Hello, after a break due to some domestics duties, I'm back.
The four valves are now finished. Two was wrong machined....
Now, all the parts are finished and I will start slowly the assembly/ fit of all the parts.
J'ai trouvé sur le net quelques informations sur le montage de ce moteur Corliss
Je profite de traduire en français
salutations
LeZap
  • CCI01052024.pdf
  • Corliss Engl.pdf
  • Corliss Fr.pdf
Ôn l'arrière du cylindre, je place 4 petits disques en aluminium
C'est pour ajuster le timing d'ouverture et de fermeture
Salutations
LZ
