compact 8 deviding head
krv3000
HI all right I original got he idea for this project from a article in model engineer so I have adapted it to fit my lath I already had the worm drive and shaft as this came from a a scrap motor.
I turned dawn the end of the shaft to move the worm drive up on the shaft then i made up the two Bering's for the front and the back of the mounting tube the tube is 1mm thick front Bering over all length is 13mm turned dawn to fit in side the tube left a shoulder 5mm from the end for the tube to but up against drilled 8.8mm then reamed 9 mm to fit the shaft back Bering 13mm long by 26mm OD turned dawn to fit the tube left 5mm at the back turned the OD dawn to 25mm drilled 8.8mm then reamed 9mm to fit the shaft I hope the picks will help right the dividing plat cut a Peace of stainless steel 80mm OD by hand 10mm thick face off both sides and mack the plate 4mm thick that's as far as i have got right pics
front and back Bering is made out of brass
This will be a good one to watch
Will be following along :)
Ps Did u get a mill yet?
Pete
HI all did a bit more today the OD of the stainless steel was 80mm this wood be turned dawn to a OD of 75mm drilled the center 9.5mm then bored the center out to 3mm deep by 25mm diameter for the back Bering to fit in to then mashend the back of the disk to form a pocket see pic then marked out and drilled for 4 m3 fixing screws if you look you Will notes that i of set one of them this was dun to form a key so that if I have to remove the plate it will only go on one way right pics
HI all well I'm nearing the end I made up the mounting plate today this was a plate 2mm thick by 40mm wide by 140mm long divided the with then drilled two 6.2mm mounting holes 30mm and then 70mm from the bottom cut the angel for the tube to fit on to the angel was dun by dropping one side of the bracket by 10mm so on side was 130mm and the other was 140mm then i put a Shaffer on it gave it a good clean and silver solder the tube in place right pics
so far so good don't have pics of drilling the dividing plate as the camera needed charging right i sharpend a cutting tool with a nice tip on it checked that it was cutting on center then i mounted the dividing plate then 8mm from the edge i scribed a line all the way round yousing the cutting tool then i Cross the line with the cutting tool this will be the starting point for the holes in the dividing plate marched out the places with calipers then drilled 2.8 then reamed m3 i then made up the locking pin out of 6mm diameter rod turned dawn the frunt 3mm by 4mm then 6mm back from that turned dawn to 4mm by 28 long i then made up the hawsing for the locking pin the one in the pics ended up in the bin i made a new one out of brass this wood be 13mm do with m10 tap by 12mm deep then drilled on center 3.8mm by 28mm deep then drilled 5.8mm by 20mm deep then with a 6mm slot drill drilled out to 6mm by 23mm deep then the 3.8 reamed out to 4mm i then made up a spasing Bush out of black nylon 15mm OD with a 9.2mm howl by 7mm thick then mad up the bracket that wood hold the locking pin 2mm thick by 16mm wide by 60mm long on the center line 13mm from the bottom drilled and tap for m8 then 28.5 from that on the center line drilled and taped m10 right pics
HI all right its all dun the last things to do was mack up a collar to fit over the tube then drilled and tap m3 this will-be the locking collar for the back Bering made up the knob for the locking pin this was made out of a old bush witch had the same internal diameter as the looking pin Holder I made a cap to fit the Busch with a m4 hole in it for the looking pin then soft soldered it on to the Busch gave it a pant job and its dun next bit will be a indexing ring for the chucks you will see in the pics that i made sumthing up just to see haw it works don't no a bawt other cuntres but in the UK their is a Swedish furnicher store if you go in you will find that they have paper tape meshers for you to mesher things up with all i did was tape one of the to my chuck for indexind and one full turn = 10mm any way I hope you all enjoyed the billed right pics
